1 - 15 of 15 Posts
Installed my new gauges today, fairly simple project. Put the car in run position to get a baseline needle location. Then, you need to take off the kick panel and cluster cover which are held in place by some pop outs. Next there are 4 screws that hold the gauge cluster in place that need to be removed. Then remove the cluster and disconnect the three electrical connectors.
Place the cluster on a bench and remove the 6 screws that hold the two pieces of the cluster together. Then remove the clear plastic piece and pull the needles gently off.
Next take the existing gauge face off (just pops off) and place the new gauge face on. Then put the needles back on in the position marked.
Go back and plug the cluster back in and check the needle location. If done correctly put the car back together in the reverse order. I like the old school look and is an affordable mod. Greatly enhanced the interior IMO!
Pictures:
[/URL][/IMG]
[/URL]
Looks great! I've been debating on whether or not to do this.
Looks good! ...a little Old School! I like it!:smileup:
Thanks for the write up, looks great.
Discussion Starter #8
LOVE this mod !!! where did you purchase the new gauge cluster?
Blackcat Customs they have several different choices. Took a month to get mine made because of their back log but definitely worth it!
Looks great...have been thinking about this for a while but am unsure whether or not I have the skill level needed to do the swap.
that's neat... if i did this i'd try to duplicate the old school, original look too... the possibilities are endless with this!
:rep:
Discussion Starter #11
:rep:
It is really a novice install the most delicate part is dis assembly and not to break the pop out that hold the plastic in place.
Thanks for the reps! I like the look as well!
Great write up and mod. . . Reps man
oh yeah, How do the needles look against the black when lit up?? Been wondering that since lighted needles are not available for the '13s and '14s
Discussion Starter #13 (Edited)
Tim, here is a night picture the needles are kind of hard to see but there is enough backlight to see the needles as the picture is a little darker than actual, if I don't like it I will add the white LED needles:
Thanks for reps as well!
Thanks wyo!, That is pretty concerning as I do enough night driving. I wonder if there is a way to get lighted needles for the '14s. . .
The Bronco looks pretty cool lit up though!
RELIVN
That looks great. I wish I would have thought of that when having mine done a couple of years ago.
Great job and idea.
1 - 15 of 15 Posts
