1 - 16 of 16 Posts
hello all been checking this site out for a while im the proud owner of a 2010 dodge challenger se........and i love it the reason i finally joined was to ask a question i purchased the car used with 93 000 km on it after a few weeks of driving i noticed at random times when i go to start my car it cranks for a few seconds then fires up and everything is good but it happens at random times (this was happening when it was warm out as well) for example i go out first time driving the car starts up no problem go to store park shut off start up no problem go to pick up sister shut off start up does the crank for a few seconds then starts and is fine then it wont happen untill another few start up's has anyone ever encountered this problem, again the car cranks for a few seconds then starts up its doesnt die out out runs smooth as ever i just dont like when it does the random crank makes it sound like a beater also i turn the key to the on position to allow the fuel pump to work sorry if if this is hard to understand again im new to this type of stuff hope someone can help me thanks and have a great day oh and im also from ontario canada EH! :smileup:
Hello and Welcome to the 'Z' from the beautiful Shenandoah Valley of Virginia. :wavey: Enjoy your Ride and the Site! You'll find some knowledgeable and friendly people to answer your questions or just entertain you. Glad you could join us!
Your challenger is exhibiting a symptom of a crankshaft sensor going bad or one of the wires going to it being loose or grounded. That has happened to a couple instances around here. If you hook up a code scanner to it it will probably show a code relating to that in history.
BTW, I moved your post to its own thread to get the proper recognition.
Welcome from AZ.
· Seeing red
Welcome to the Z from New Mexico! You have found the absolute best spot for a Challenger lover to be except for behind the wheel! Enjoy the ride!
· Mopartial to Challengers
40 years ago we could have broken out the timing light, checked the sparkplugs, performed a tuneup and called it a day, LOL. Take bad8nti's advice. I'm sure it's a solid solution.
1 - 16 of 16 Posts
