Welcome to the forum!
For instance:Our old 2015 SRT 392 with the A8 trans, dynoed more than Dodge rated it for Completely stock (433 rwhp on a Mustang dyno in 72° weather, which is over 500 to the crank). Maybe it was just a factory freak though! Who knows but She would Scoot!
My second experience was a 25 horse "Sneaky Pete" setup on my old 1976 440 Mercury Sno-Twister. It didn't set the world on fire either but was enough sometimes to give me the edge that I needed when drag racing it! It had a 2 lb. bottle that fit under my seat. I hollowed out some of the seat pad to hide the bottle under there. To change the bottle, I unsnapped the seat cover and threw the new one in. I had five little bottles and would go through a few in a weekend.
My last and Greatest use of N20 was in my old 68 Camaro. I had built a 540 c.i BBC with some Sick AFR aluminum heads, full roller valvetrain, etc (817 hp before juice) and then installed a plate system and also a Fogger setup too. The plate was a 150 shot for coming out of the hole and the Fogger was set up to spray another 250 when I wanted it to. It was a blast and worked like a charm too and allowed that car to run 9.18 @ 156 mph (3600 lbs.). It was a Bunch of fun but spraying that much would empty a bottle pretty quickly.
If you stay with a small shot (under 100 hp) you 'll probably be fine as long as you have a window switch that will only spray under WOT (Wide Open Throttle). It's when Folk's get Power Hungry and spray too much that things can and will get out of hand. As stated, ring gaps are the problem and more heat doesn't help with that.I know it can only take so much spray at a time and the pistons aren't forged which I've heard could be problematic.
You think that Dodge has left alot on the table with these cars? I don't, because a set of headers MIGHT get you 15 rwhp, while a set of headers on my old LS1 Vette got me 40 to the wheels. Tunes don't get you a ton of power on these cars and I think that Dodge did a Great job on their tuning. GM is famous for leaving power on the table but Dodge does a Great job delivering as advertised. I've found that the factory numbers always run at least advertised and sometimes more.So what kit did you buy? Link to the kit please?
I also considered Nitrous but after much research decided not to go that route.
Have you already gotten an unlocked ECM and gotten a tune, because there is plenty of power that Dodge has left on the table, maybe high flow cats and a good tune will give you the extra power you need?
Or are you going to race the car?
Welcome from South Carolina.
I agree!Welcome to the forum. Your stock Scat Pack brakes are more than adequate for any Nitros shot that can reasonably safely be run on a stock 6.4L.
I'll start with my experiences. I had a 1987 Pontiac Trans Am that had a TPI 305 in it that I put a 100 horse shot on. It worked fine and gave an otherwise Anemic motor the kick in the pants that it needed. It probably turned a 15 second car into a high 13 second one but it was fun (except for always filling N20 bottles).Which of you Nitrous Knockers has actual first hand experience with Nitrous and, What was your experience? Just Curious.
Maybe you didn't fine tune it because I had the same setup on my old 1986 Trans Am and it worked fine without issues. Every car and kit is different though.I had a 100 shot N20 kit on my 86 IROC Z....it was a waste....not enough to even notice, and it did cause some issues, like popping thru the intake and taking out the mass air sensor.
It was a kit that came with pre-matched jets, so all you did was plumb it in. I eventually took it off and sold it.
