Petal Commander install/review with pictures
Discussion in 'Challenger Performance Mods - Engine - 6.4L HEMI' started by cms1528, Sep 12, 2017.
  1. cms1528
    cms1528 Active Member Photo Winner! Public Safety
    Feb 15, 2010
    1,019
    Media:
    3
    Albums:
    1
    395
    Baltimore, MD
    Vehicle?:
    Challenger
    Model Year?:
    2011
    Trim?:
    SRT-8
    Color?:
    Green with Envy
    Transmission?:
    Auto
    NO! It does not change any ECM features, it's plug and play only. Five mins. to install and then you're off to the races. I would remove it before you take it into a dealer for work if you had a concern.
    gambit161 and shooterjgs like this.
  2. Evil Dave
    Evil Dave New Member Military
    Dec 14, 2017
    39
    16
    Gender:
    Male
    PA
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    R/T Scat Pack
    Color?:
    Billet Silver Metallic
    Transmission?:
    6-Speed
    Thanks for your review. Still waiting out the cold here to try mine. One clarification: the linear vs logarithmic comparison is about the pedal behavior in any one setting, not the shift from one setting to another.
  3. Evil Dave
    Dec 14, 2017
    39
    16
    Gender:
    Male
    PA
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    I believe either method could support 32 settings. If the PC is linear and just compressing the stock pedal action into a shorter effective pedal range, then each full increment could be broken into 1/4 non-overlapping increments, or there could be overlap, where City +4 and Sport +0 are identical, for example.
    Also, curious to see what base value range for log works well for a throttle. As others have noted, too sensitive and too sluggish are both undesireable.
    Lastly, isn't reverse log called exponential? An exponential function would have low sensitivity close to zero, but high near the physical pedal limit, bc the curve is concave w respect to the X axis. A log function is the opposite, Y rises steeply from 0 then flattens approaching the physical limit of X (full pedal), bc the curve is convex to the X axis. Folks have complained of off-zero jumpiness (oversensitivity) with the highest PC settings, which would not be indicative of an exponential function.
    Tx
    TheOldGuy likes this.
  4. TheOldGuy
    TheOldGuy Will Fabricate Anything For Space Shuttle Ride Site Supporter Level 3 MOTM Winner!
    Oct 22, 2013
    1,997
    Media:
    19
    Albums:
    2
    3,776
    Gender:
    Male
    Right Here, Right in the Beautiful State of Maine
    Vehicle?:
    Challenger 2016
    Trim?:
    R/T Scat Pack
    Color?:
    Ivory Tri-Coat Pearl
    Transmission?:
    6-Speed
    You explained it perfect. It just operates backwards. Today I added about 20 lines of code and had the entire travel of the pedal of the Ram 2500 in just a 1/4 inch of travel. I can do donuts just by touching the pedal. Its incredible albeit dangerous. It is really aggressive. I AM NOT leaving it that way. I just had to test something. I got to go unplug it before it gets dark out. It's nice having heat in the garage.
  5. Evil Dave
    Dec 14, 2017
    39
    16
    Gender:
    Male
    PA
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    At least you are testing on a RAM and not a Hellcat. We'd like you to stick around for a while.
  6. Evil Dave
    Dec 14, 2017
    39
    16
    Gender:
    Male
    PA
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    You never answered why car engineers might seek linear behavior for driver controls. I believe the answer is safety and driver predictability, because a linear function is predictable across its range from any starting input to any ending input value. The vast majority of drivers would find this easier to control because no matter whether you are at: 0 pedal, half pedal, or approaching full throttle, you can expect the same output behavior for each increment of pedal change. A driver could adapt to a variably sensitive pedal, but at any speed you want a pedal that is comfortably controllable via foot. I don't want 3/4 throttle in top gear, at 120 mph, to be over sensitive, and off-idle, in first gear, I don't want a sluggish response. When you adjust an exponential function to accommodate these desires, I believe you'll approach a flattened curve that fairly approximates y=nx across the range of allowed outputs. i imagine you could chose different functions or parameters, based on how quickly x is changing, to mitigate...
    Maybe we are hijacking this thread. I've been accused of worse.
  7. TheOldGuy
    Oct 22, 2013
    1,997
    Media:
    19
    Albums:
    2
    3,776
    Gender:
    Male
    Vehicle?:
    Challenger 2016
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    Hijacking the thread? Why? it's all the same stuff! And yes it is linear. Because I'm working alone, I set up a camera looking at the throttle body valve with the intake boot off and the response of the valve is directly linear according to pedal position. I had to know this before I started messing around with this whole project.
    Ya know... back in the day when we had mechanical linkages, the 3 deuces carburetor setup on a lot of systems were a log function. The first half or more of the pedal travel was just the center carburetor and then a stud would grab the linkage for the front and rear carb and open them fully in the last section of pedal travel. Watch the video carefully and you will see what I mean.
    Jazz Blue SP 392 likes this.
  8. Evil Dave
    Dec 14, 2017
    39
    16
    Gender:
    Male
    PA
    Vehicle?:
    Challenger
    Model Year?:
    2017
    Trim?:
    R/T Scat Pack
    Color?:
    Transmission?:
    6-Speed
    I was just joking, bc ShooterJGS griped earlier.
  9. DCTA2017
    DCTA2017 Member Military
    Jul 31, 2017
    130
    Media:
    8
    Albums:
    1
    143
    Gender:
    Male
    Amarillo, Texas
    Vehicle?:
    Challenger T/A
    Model Year?:
    2018
    Trim?:
    T/A 392
    Color?:
    B5 Blue
    Transmission?:
    8-Speed Auto
    Need help ASAP! Trading the car in and getting a 392 T/A. I can’t get the plug removed from pedal commander that goes directly into the gas pedal plug in. Does the red need to be pulled out or pushed in on the pedal commander plug going into gas pedal.
  10. shooterjgs
    shooterjgs Active Member Military
    Jan 20, 2016
    1,189
    1,023
    Gender:
    Male
    South Texas
    Vehicle?:
    Challenger
    Model Year?:
    2013
    Trim?:
    SXT Plus
    Color?:
    Brilliant Black
    Transmission?:
    Auto
    Can't tell but from the pics it looks like it needs to be pulled... Hope you get it done.
  11. DCTA2017
    Jul 31, 2017
    130
    Media:
    8
    Albums:
    1
    143
    Gender:
    Male
    Amarillo, Texas
    Vehicle?:
    Challenger T/A
    Model Year?:
    2018
    Trim?:
    T/A 392
    Color?:
    B5 Blue
    Transmission?:
    8-Speed Auto
    Is there a trick to pop off those two tabs to let the felt cover down? I don’t want to screw this one up. Cover wise
  12. cms1528
    Feb 15, 2010
    1,019
    Media:
    3
    Albums:
    1
    395
    Baltimore, MD
    Vehicle?:
    Challenger
    Model Year?:
    2011
    Trim?:
    SRT-8
    Color?:
    Green with Envy
    Transmission?:
    Auto
    Push the red tap up to unlock the plug. Then pull the plug to separate. The felt cover is not really attached to anything, if I recall correctly just be gentle with it.
    shooterjgs likes this.
  13. DCTA2017
    Jul 31, 2017
    130
    Media:
    8
    Albums:
    1
    143
    Gender:
    Male
    Amarillo, Texas
    Vehicle?:
    Challenger T/A
    Model Year?:
    2018
    Trim?:
    T/A 392
    Color?:
    B5 Blue
    Transmission?:
    8-Speed Auto
    This felt cover is being a nightmare for me. Those two flat plastic screws won’t release
  14. cms1528
    Feb 15, 2010
    1,019
    Media:
    3
    Albums:
    1
    395
    Baltimore, MD
    Vehicle?:
    Challenger
    Model Year?:
    2011
    Trim?:
    SRT-8
    Color?:
    Green with Envy
    Transmission?:
    Auto
    Sorry for your trouble but I did not have to go through any felt covers that were attached to anything I can remember.
  15. Granite Ghost
    Granite Ghost Member Public Safety
    Dec 10, 2016
    371
    Media:
    11
    Albums:
    3
    710
    Gender:
    Male
    Paso Robles, CA
    Vehicle?:
    Challenger
    Model Year?:
    2016
    Trim?:
    SXT Plus
    Color?:
    Granite Crystal
    Transmission?:
    8-Speed Auto
    His is a '17, and yours is an '11. I'm guessing the earlier models configured things a little differently regarding panels under the dash, etc. Just a guess. My '16 has the panel of which he speaks. It's basically a filler panel, below the main dash panel, that covers all the wiring, etc. under the dash. :)
    DCTA2017 and shooterjgs like this.
  16. shooterjgs
    Jan 20, 2016
    1,189
    1,023
    Gender:
    Male
    South Texas
    Vehicle?:
    Challenger
    Model Year?:
    2013
    Trim?:
    SXT Plus
    Color?:
    Brilliant Black
    Transmission?:
    Auto
    That's got to be it cause mines a 13 and I'm not seeing it also...
  17. Granite Ghost
    Dec 10, 2016
    371
    Media:
    11
    Albums:
    3
    710
    Gender:
    Male
    Paso Robles, CA
    Vehicle?:
    Challenger
    Model Year?:
    2016
    Trim?:
    SXT Plus
    Color?:
    Granite Crystal
    Transmission?:
    8-Speed Auto
    Yup. I went out to look at mine, and was gonna pull on the plug to get the answer to his question. Then I remembered and saw the panel, and didn't wanna hassle with pulling it apart. You can't even see the harness, or anything else under there, without removing the lower panel. If yours doesn't have it, it probably started with the other major revisions starting in '15. Just a guess.
  18. cms1528
    Feb 15, 2010
    1,019
    Media:
    3
    Albums:
    1
    395
    Baltimore, MD
    Vehicle?:
    Challenger
    Model Year?:
    2011
    Trim?:
    SRT-8
    Color?:
    Green with Envy
    Transmission?:
    Auto
    Yep, like I said I didn't have to go through a panel to get to the plug. Is the panel held in place by those christmas tree type retaining plugs?
  19. Derecho
    Derecho New Member
    Dec 15, 2016
    35
    73
    Gender:
    Male
    Kankakee, IL
    Vehicle?:
    Challenger
    Model Year?:
    2016
    Trim?:
    SXT Plus
    Color?:
    Bright White
    Transmission?:
    8-Speed Auto
    I've got a 2016 SXT Plus I installed the Pedal Commander on and that panel was actually pretty easy to remove - for me anyway; you just have to pull down firmly but evenly on the panel area surrounding each plastic pin. Don't jerk it, but pull down with even, but firm pressure. The fiberboard panel will pull right off. Those pins are friction lock type pins, not screw on's. When they are still new and have never been taken off before they can feel like they won't come off, but with gentle applied downward pressure working from side to side on each pin the panel will detach without damage. Another tip that might help you is to pull down the edge of the panel and slide your finger tips inside the panel as close to the pins as you can get them while pulling down...and work side to side to bring the panel down and off evenly so it doesn't bind from being crooked.
    To reinstall, simply line up the pin and press firmly back into place. Hope this helps!
  20. DCTA2017
    Jul 31, 2017
    130
    Media:
    8
    Albums:
    1
    143
    Gender:
    Male
    Amarillo, Texas
    Vehicle?:
    Challenger T/A
    Model Year?:
    2018
    Trim?:
    T/A 392
    Color?:
    B5 Blue
    Transmission?:
    8-Speed Auto
    Got it fixed. Yeah. I did some minimal damage to the panel. But it’s not something someone would see. So I’m not concerned with it. Once it put it back in place. All is well. Thanks for the tips. Finally did get it installed. Still getting used to there not being a clutch. Left foot has ventured to the unknown clutch territory a few times. Lol
    Derecho and shooterjgs like this.
Share This Page
