21 - 24 of 24 Posts
I am interested in the fuel cell with pump and the regulator. I recognize the DW200 pump as the 255 lph pump which should be more than I need. Is the regulator adjustable? Also what dimensions and mounting for the fuel cell? Would you be willing to split it up? I am going to be drilling and tapping the side of my TB to mount a nitrous spray nozzle, as my setup is too tight for a n2o plate to fit. Thanks again.
Tank dimensions
12” long, 13 1/2” across the mounting feet
7” wide 7” high
Has AN fittings, -6 I believe, includes the hose seen in the misc items picture.
Discussion Starter #24
Sorry about the late response, I have been a bit busy with work lately thanks to half of California being on fire. I will have to take some measurements to see if there is some place I can stash the cell that is accessible. Honestly, $350 is a bit more than I was planing to spend on the cell and pump setup.
The plates and solenoid setups won't work for me as my car uses the Granatelli 95mm TB so it does not match the stock bore, and it does not match a hellcat bolt pattern either.
21 - 24 of 24 Posts
