Status
Not open for further replies.
1 - 20 of 82 Posts
Dodge Challenger Vendor
R1 Concepts Inc. is proud to offer Premier Series Challenger Rotors!
I am offering the Premier series rotors. R1 Premier rotors provide the ultimate stopping power needed for demanding driving and harsh conditions. Manufactured using more Carbon, Chromium, and Molybdenum, these high carbon rotors offer increased braking performance and strength. A center split core casting provides greater stability. Black Electro Coating protects against rust while extending rotor life. Mill balancing and double disc grinding reduces thickness variations for smoother stopping, minimal vibration, and improved break-in. All R1 Premier rotors are designed for direct fitment: no modifications are required.
What separates R1?
Often Imitated, Never Duplicated. Here at R1, we take into account numerous precautions in machining rotors. We drill our rotors in house using state-of-the-art CNC machines and follow strict procedures and standards such as drilling between each vane structure. This will allow the rotor to retain its structural integrity and overall strength with optimum thermal transfers. We utilize smaller diameter drill bits for smaller diameter holes and each hole is counter-sink to add strength. You also have the option to go with slotted only or even a custom design with your own logo. Every R1 rotor that comes with slots will come with our exclusive "Diamond Slot design" (45 degree angle end points), to help release trapped debris. Our diamond slot design is also a good indicator for rotor wear. We also offer optional Cryo Treatment at an additional cost. (Cryogenic treatment is a process that improves the performance and life of the rotor by strengthening the metallurgy. This process will help to give an extra level of protection against warping).
*WARRANTY*
Here at R1 Concepts Inc, we stand by our products. We offer a one year warranty on warping and cracking on all R1 brake rotors due to manufacture defects and workmanship.
Available Styles
Slotted
Drilled
Double Drilled & Slotted
Dimpled & Slotted
FT/RR Premier Rotors
Challenger (3.5L RWD & Solid Rear Disc)
: $345 SHIPPED
Challenger (3.5L AWD & R/T) : $390 SHIPPED
Challenger (SRT8) : $460 SHIPPED
SE & R/T PADS
FT/RR HAWK HPS PADS: $120
FT/RR HAWK CERAMIC BRAKE PADS: $135
SRT-8 PADS
FT/RR HAWK HPS PADS: $160
FT/RR HAWK CERAMIC PADS: $170
SS BRAKE LINES
FT/RR STOPTECH SS BRAKELINES: $170
BRAKE FLUID
Stoptech STR600 Brake Fluid: $16
Stoptech STR660 Brake Fluid: $25
CALIPER PAINT
G2 Caliper Paint: $30
(red, yellow, blue, purple, green, gold, black, silver, pink available)
*Contact Info*
Contact: Kevin
Kevin@r1concepts.com
Phone Orders: 1-888-712-6623 ext. 7022
www.R1Concepts.com
I have a 2014 RT/Shaker with an SRT Brembo conversion. All parts are standard 2014 SRT what pads do you recommend for a daily driver?
13,000 miles and rotors are warped and pads are at 3mm. I'm looking for something that will last longer.
Thanks!!
Discussion Starter #6
Thanks!!
PM sent!
1 - 20 of 82 Posts
Status
