1 - 5 of 5 Posts
I have 2017 challenger RT plus and I'm searching the best option for winter setup. Will r18 from SXT or similar fit on my setup? I tried to search forums, but I have only found that r18's fits pre 2015 model years RT's.
As long as they are not from an AWD SXT and you do not have Brembo brakes they should fit.
Hello Sir, Have to ask... I wanted to put 18's on my 2021 Challenger Scat Pack for that fat tire look, but the dealer gave me a bit of a runaround. Is it possible to do that as long as the offset and bolt pattern are the same? A friend has a Cobra kit and his 15" billboard tires look really cool. Thanks
Maybe, if you have the 6 piston Brembos, I would say probably not. But you may have to use spacers. Check with a tire/ wheel shop in your area.
1 - 5 of 5 Posts
