Here are the settings on mine, I'm tapped into the cylinder 1 coil driver wire. First dial is at 5, second dial at 0, and switches all towards the bottom.What cylinder setting is correct for a 2012 RT? The raptor web site says
"The cylinder setting must be set to "1 cylinder" mode since we will be reading from a single coil."
Is that "1/2PPR" setting?
Thank you
