I have a new R/T badge for the trunk deck. What's the best way to get the old one off without damaging the paint.
Thank you in advance.
The shirts in my closet are all hung equidistant with buttons all pointing the same way and matching hangers over the rail. But then, everybody does that, right?and James says I have OCD, LOL...
My Replacement Scat Emblem on the old 1320 was actually set in a Jig (template), made it so easy 👍
Soldier, You can also use Dental Floss, used it to remove / change my old Scat Pack Emblem on the Rear Wing on the 1320, and removed the DODGE on the 1320 and Hellcat.
Dont ask me why but I have a bag filled with Dental Floss on a little Dinosaur handle (I think they're Dinosaurs) was so easy using that![]()
Heat with a Hair Dryer on High and Use Fishing Line after you can use a Rag with 90% Rubbing Alcohol from Amazon or very light damp Rag with Lighter Fluid on a super soft
Microfiber Cloth just enough to wet it and rub gently a few times to remove the residue. I do not recommend Goo Gone because it makes a Gooey Mess before it cleans stuff off.
After you get it cleaned off wipe again with Rubbing Alcohol and then you should be good to apply the new one.
That's a great tip. Thanks !!!Heat with a Hair Dryer on High and Use Fishing Line after you can use a Rag with 90% Rubbing Alcohol from Amazon or very light damp Rag with Lighter Fluid on a super soft
