1 - 10 of 10 Posts
I looking for Wheels & Drag Street Radials for the rear but I do not know what sizes are available and can use on my 2015 392 Challenger.
Any suggestions would be appreciated.
Thanks,
On my 2015, I used Mickey Thompson 305/35-20 ET Street S/S's...A good DR for daily use...Albeit for not a lot of miles...Maybe 3500...You should get some good info here on mileage...I just used mine for going to and from track days...and you'll need a new 10.5" wheel...
I installed Mickey Thompson ET Street SS drag radials (305x45x17) on Race Star 17"x9.5" rims. The tire size was as close as I could get to match the height of my factory 305/35/20's. I switched to the 17" rims because you get more sidewall which helps with traction, and they are $150 per tire cheaper than the 20" Drag Radials. You may need a slightly different size if you want to match the height of your factory tires.
262839
262840
Discussion Starter #4
On my 2015, I used Mickey Thompson 305/35-20 ET Street S/S's...A good DR for daily use...Albeit for not a lot of miles...Maybe 3500...You should get some good info here on mileage...I just used mine for going to and from track days...and you'll need a new 10.5" wheel... View attachment 262845
Thank you for the info.. much appreciated.
I like your setup and I know a place in Tempe, AZ that's selling but I am not sure if it is a good deal.
Do you think that 2 Race Track Drag Wheels 17x9.5 and 2 MT Drag Radials 305/50/17 for $1500 sound about right for the price??
I run Nitto 05R, 315/35 R20 on the same style wheels as my Nitto Motivo tires of the same size for the rears on the street. Milanni Tycoon wheels 10.5" wide rear 9" fronts.
NO !!!! I paid under $1000, including the rims, Tires, and Lug nuts. I think I negotiated a little to save money, but not much, and Mickey Thompson had a $75 rebate at that time. Here are the links.
I think they are having a sale coming up for Black Friday?
Rims $245 each - Race Star 92 Drag Star Bracket Racer Metallic Gray 17x9.5 5x115BC 6.125BS Dodge #92-795452G
Tires $293 each - ET Street® S/S
Lug nuts around $45 - Race Star 14mm x 1.5 1.38in. Shank W/ 7/8in. Head Challenger & Charger Closed End Lug Kit - 10 PK #601-1432-10
If I go to the track more than a couple times next year I am going to go with Race Stars Black wheels, 18 in the front with skinnies and 17s in the back with some sticky Mikey "Parts Breakers". But if I lose interest I will put my Nitto NT05Rs on the back and burn them off cruising around. I need some new Motivos next year as well. Is there anyway to run 315/35 R20 tires all the way around on an R/T? I will have (4) 10.5 wide rims, may as well run fatties clear around on the street.
1 - 10 of 10 Posts
