1 - 5 of 5 Posts
So I have a dark spot near the lumbar section of the seat on my red leather after traveling for 9 hours it appears as though the red leather has rubbed off? Has anyone had this happen to them the vehicle is a 15 charger and only has 15,000 miles on it. I’ve tried a 3:1 cleaner and micro fiber towel with no luck. I can’t imagine that the red would rub out after only 15,000 miles. I purchased the car from car max about 4 weeks ago.
Discussion Starter · #4 ·
I saw a hint of this on my white Katzkin after only a few drives. I figured it to be my belt that was causing the discoloration. I used a good leather cleaner and most of it came out. Now i won't wear a belt when I drive it and haven't had the problem persist.
Thanks for the info, I wear a duty belt for work Im sure that's what is causing the issue. I am just hoping it can be fixed or cleaned with relative ease.
Hello and welcome to the brotherhood of muscle, go Bucks. Do a youtube search, sure you'll find a solution there.
1 - 5 of 5 Posts
