I found this in our Knowledgebase section. http://www.ChallengerForumZ.com/showthread.php?t=50590
Hope it helps ya out!
Just what my nerves need to hear lolTwo things, there is a screw located right beside both head lamps that is tough to get to (have to reach up from the bottom once you get the pans off). It has a 10mm nut I believe and the stud is about an inch long. I used a 1/4 inch drive deep well socket to get to mine. The other thing is once you get the two screws out in each wheel well you will need to pop the fascia straight out to the side as it pops together. It's kind of unnerving the first time you have to yank it apart.
