I totally agree with the posts above.
The RIPP website claims a 20 RWHP gain on a 5.7L engine, I seriously doubt that.
Since RIPP got famous from supercharging are the tested 5.7L HEMI engines supercharged as well? Even though they show naturally aspirated engines in their pictures, that may not be the engine they actually DYNO'd to make those claims?
When supercharged you should go to a colder plug and with that colder plug you run a tighter plug gap, well if the OEM coil specifications were satisfactory for the wider naturally aspirated plug gap, surely it is even overkill for the tighter gap.
So I am wondering if the increased spark voltage will seriously shorten plug life as many higher powered racing coil packs do?
These HEMIs run 16 plugs and just changing those is expensive and time consuming so is the increased spark worth it, even if it does what they claim?
I guess that is up to the person spending the money, but as one that prefers the set it an forget it approach, and enjoy driving your Challenger, well you should have gotten the point by now. Ry
