Welcome from Alabama on your first post. Love that green T/A!Kengrey, beautiful choice !! I'm in.
Love PCP! What I would have if it was available in 21'. Happy with Indigo Blue though!
Thanks SKT PK 9 Man! I thought they might would continue the PCP again later, but I'm leaning towards they will no longer have it. Darker blues are my favorites in colors, and the Indigo Blue is a beautiful color. If I didn't have the PCP, Indigo Blue and White Knuckle would have been my other choices.Love PCP! What I would have if it was available in 21'. Happy with Indigo Blue though!
TorRed, right? Love the window tint. The banana strip not so much. Great car!
I was going to remove the shipping banana but scrapped a curb parking and now I’m on the fence.TorRed, right? Love the window tint. The banana strip not so much. Great car!
Take it off before dirt gets in there and scratches the plastic, Just be careful! Backing in is my strategy. My driveway is so steep if I pull in it scrapes. Have to back in.I was going to remove the shipping banana but scrapped a curb parking and now I’m on the fence.
Take it off! I have learned to drive mine without scraping the spoiler. Remember to drive at an angle when you have a dip in the road or a driveway. Helps eliminate the problem a lot!I was going to remove the shipping banana but scrapped a curb parking and now I’m on the fence.
I am very careful to avoid bumping my front spoiler. Very, very careful. Paranoid.I was going to remove the shipping banana but scrapped a curb parking and now I’m on the fence.
If it's been very cold your tires will normally drop in pressure because tires normally lose or gain 1-2 PSI (pounds per square inch) for every 10℉ change in temperature. This is caused by the air becoming denser as it gets colder which, as a consequence, lowers the tire pressure. Theoretically, your tires could lose 4 PSI over the weekend if the temperature drops by 20℉. While your tire pressure should bounce back after the cold spell passes (assuming it does pass and your tires have no leaks or holes), low tire pressure shouldn't be ignored. I'd suggest filling them up to the lowest psi number in your owners manual if you've been having sub- freezing temps and then check daily to make sure you don't have an actual leak somewhere.I’m going to take it off tomorrow. I had to watch a YouTube video to learn how.
Anyone have any problems with a slow leak in one of their tires? Passenger front is losing air slowly. I’ve tightened the valve stem innards but think it’s still leaking? Will bring it to the dealer if necessary but waiting for decent weather.
That's what I do as well, Betty. I aways back into a space if needed as a last resort. At least the rearview camera makes that a little easier. I've gotten used to driving and parking in a manner to take care of the front spoiler. It's become a normal driving habit.Take it off! I have learned to drive mine without scraping the spoiler. Remember to drive at an angle when you have a dip in the road or a driveway. Helps eliminate the problem a lot!
Excellent explanation about the tire pressure. I am a little obsessive about tire pressure, and where I live it gets darn cold. So I check that a lot. I added air about a month ago, as soon as we started getting colder temps. I haven't driven the Scat for two weeks, and will be driving it tomorrow. That is the first thing I will check!If it's been very cold your tires will normally drop in pressure because tires normally lose or gain 1-2 PSI (pounds per square inch) for every 10℉ change in temperature. This is caused by the air becoming denser as it gets colder which, as a consequence, lowers the tire pressure. Theoretically, your tires could lose 4 PSI over the weekend if the temperature drops by 20℉. While your tire pressure should bounce back after the cold spell passes (assuming it does pass and your tires have no leaks or holes), low tire pressure shouldn't be ignored. I'd suggest filling them up to the lowest psi number in your owners manual if you've been having sub- freezing temps and then check daily to make sure you don't have an actual leak somewhere.
This could likely explain the spoiler scraping incident you noted above, although with the deeper Scat front spoilers, you still should enter driveways and steep exits slowly at an angle to limit scraping as the other members have suggested.![]()
