Scat Pack Widebody R/T Factory tires - Road Force balance
321 Views 5 Replies 5 Participants Last post by  Forestvillechallenger
Has anyone experienced any issues with their Pirelli tires from the factory requiring road-force balancing due to vibrations at highway speeds?
Car: 2022 WB, Scat Pack R/T.
I have had to get one tire road-force balanced, and the issue appears to still linger, so I will have to get it done again.
I wanted to know if my second visit stems from a poor initial balance job, or if these issues can reoccur and require a second balancing.
Thanks!
Check the Tire for Separation, Check the Lug Nut Torque, Air Pressure, Check Wheel for being Damaged making sure its not bent.
Reactions: 1
Thanks, but those possible mounting issues are not the proximate cause, nor the wheel because I have not damaged it.
The dealership did the initial repair with a road-force balance job, and the car drove fine for about 3 days, since this past Tuesday.
I am thinking that the technician may have overlooked a detail in this job (did not properly run the machine or do other related tasks), but I could be wrong and the tire is defective.
This is why I was wondering if tires that are road-force balanced are corrected more than once within a reasonable amount of time between repairs.
The p zeros suck I would put some michelin pilot sport 4s on asap
Reactions: 1
Thanks!
Have run Pirelli tires on a couple of cars for a total of over 200K miles and they were fine.
A road force balanced tire/wheel that runs smooth then this smoothness deteriorates and (listing a few biggies) assuming it is not leaking air (which is easy enough to check/eliminate) and you have not bumped the tire up against a curb or run over a curb cutting a turn into/out of a drive way too sharp or the wheel has not lost any weights or the tire is not spinning on the wheel points a very fat finger at a bad tire.
If you take the car in and have the wheel/tire checked for balance and it needs adjusting that would have to be confirmation the tire is bad.
Reactions: 1
had that problem with my 2019 scatpack widebody after several months of taking it back to the dealer after force balancing all 4 tires they replaced one tire. it was better but still is vibrating a little. this was all going on with just 500 miles on the car.
