I think you answered your own question with the last sentence. If you do anything, just a small cam.
I think you answered your own question with the last sentence. If you do anything, just a small cam.'73 Challenger, 340 completely stock and original.
110K miles and in super shape.
The question is..................
Since I am having the engine "freshened up", should I "warm" it up a bit and add some go fast parts to the internals???
I am keeping the car as close to OEM as possible and don't want to screw things up.
This^^ maybe not the headers, 202 heads and a 68 340 cam and leave the external pieces stock.Yes, since you have the low compression 340, I'd bring it up to 71 and earlier 340 specs. That is I'd install some 2.02 valve heads with hardened valve seats so you can run unleaded gas, bump the compression, maybe add a mopar purple shaft cam or the older 340 manual trans cam and a set of headers. Now that's just me and having owned a few 340 cars in the past I always felt the need to squeeze a few more ponies out of them. The 340 is a good motor but after 71 the power dropped a good bit, so again if it was me I'd warm it to the earlier specs or a bit better. Good luck with your decision.
