I have 6 piston Brembo's on the front of mine and think these are the most troublesome, for me at least. Over the past year, I've experimented with 5 different pad manufacturers (I know, pretty anal) and have learned a few things. Pads designed for the street with a mixture of ceramic work pretty well with minimal dust and noise but terrible fade when worked hard, especially at the track. Track pads are more metallic and have good bite at the track but more dust and noise overall.
Many folks like the PowerStops but I was not so impressed, except for the low dust and squeal free performance. Not a good pad for panic stops when cold at highway speeds and of course at the track.
Hawks were excellent overall performers but really noisy on the front. I kept these on the rears and experimented more for the fronts.
EBC Redstuff's were a huge let down. For a pad manufacturer that claims a quiet and dust free pad, these failed in all accounts. Squealed like crazy and a surprising amount of dust created. Performed OK but eliminating dust and noise was a major goal.
I also replaced my rotor rings and pads with DBA (Disk Brakes Australia). Rotors are great and pads have excellent performance and customer service but front pads did squeal a little.
Lastly, I tried all ceramic, Disc Italia, pads on the front and they are relatively quiet and low dust but pretty bad fade at the track. For this summer, I'll most likely stick with these then switch out to the OE Brembo pads for track days. I haven't found a better overall pad than the Brembos except the excessive amount of dust. Looks like dust is a given if looking for a good track pad.
I haven't tried these but have had very positive review from friends with StopTech pads with street and track use but they have the 4 piston front and rear calipers.
I really wanted to test the Akebnono pads but they are not making them for 6 piston calipers so would love to hear from anyone using them on their 4 piston setups.
Above all, make sure the pads are properly bedded in per mfg'rs recommendations.
Keep in mind this is just my experience and know many others have had different results so take this review as you will
