1 - 9 of 9 Posts
My 2019 challenger Rt was not starting at all yesterday. Battery and alternator checked out fine. Lights and everything else will come on, but it just won't start. Anyone else has/had issues with their starter? I'm a little concerned considering my car is only 2 yrs old with 35k miles.
2020 Challenger R/T Scat Pack
Can you be more specific?
Does anything happen at all when you push the start button? Do you hear a clicking noise when the starter is expected to engage? Does the starter even try to turn the engine over? Does it turn it over very slowly? Does the starter motor spin very fast but not crank the enginel?
Reactions: challengerWill
2016 Challenger SXT Plus
Swap the starter relay in fuse box under hood, with the start/run relay. start/run relay may be bad.
Discussion Starter · #4 ·
The push button worked the 1st time. But didn't worked the 2nd and everytime after that. I heard one small click with the remote start. Starter didn't try to turn the engine over. It doesnt turn over at all. Motor doesn't spin at all
Have you checked the relays ?
1 - 9 of 9 Posts
