No matter your horsepower level, if you cannot get that power to the road you're just spinning while lower powered vehicles are flat walking away from you off the line. B Mason said it best when he suggested starting your 5.7 upgrades from the rear forward to get the power to the ground, then worry about increasing the engines output. As for myself I did the opposite and then proved the hard way what he said was exactly right. Because once my power level got me melting the rear tires, or should I say tire, I was not going anywhere fast off the line, it was an impressive tire spinning show, but that was all it was.
When I first saw Challenger advertisements burning down the tires I first thought that was so cool, until I was given a ride in a Hellcat Redeye and realized if he hammered it, he wasn't going forward fast off the line with his 797HP. So HP to weight ratio and forward momentum has quite a few factors involved to actually get the vehicle off the line. Most of the 5.7L automatic transmissions are fitted with open or conventional differentials using computer assisted traction control giving the owner the illusion of both tires producing traction.
That computer controlled traction uses your ABS braking system to apply brakes to the spinning rear wheel in an attempt to shift traction to both wheels.
Isn't that wonderful!
So many times I've longed for the best off the line I could possibly get and all I really needed was to apply the rear brakes? NOT!
Who honestly even thinks to achieve forward momentum and get off the line requires applying any braking what so ever to the rear wheels that are pushing you forward?
However the electronic traction control works OK, until you start increasing engine performance and you hammer it to do an off the line burn out and leave one line of rubber on the road, usually the passenger side rear wheel, how embarrassing is that coming from a Dodge Challenger!
Unless you've experienced that yourself you think I don't know what I am talking about, but those of you that have swapped to a Limited Slip Differential now know the difference real traction is.
Which brings up the next problem with traction the 245 width tires, that is really an entire subject all its own as rim width determines the width tire you can safely run on the rear. Tire width has to be matched to the rim width for the tire to sit flat to the road for the best overall traction. Which usually requires going to wider rims to run wider tires.
