Since the tips and tricks website is closed, does anyone have the instructions for dealer to activate the drl"s, they told me my car doesnt have that feature and cant be programmed, i think they dont know how
[FONT=Verdana,sans-serif][SIZE=-1]
(Daytime Running Lights) and Activation of.[/SIZE][/FONT]
This is where the inboard AMBER turn signals both come on bright and stay on while driving and properly switch OFF/ON during turn signals. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
The bright amber lights highlight the vehicle for others to see it better during the day, hence the name Daytime Running Lights. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
When you select headlights on, the DRL's switch off and AMBER turn signals now go to low power filament and will glow bright on lane [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
change indications as normal. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
In Canada it is against the law to remove/disable the DRL on any vehicle 1990 and newer. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Also all vehicles imported that are mfg 1990 and newer must have them. They are considered [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
basic safety equipment[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
-[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
like brake lights or headlights.[/SIZE][/FONT]
Note to Service Tech's to Activate DRL's on the Dodge Challenger in the United States.[/SIZE][/FONT]
You do not have to Change [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
COUNTRY[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
code ([/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
ie[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
. Canada, Unites States, etc.) to do this. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
It is NOT in the vehicle [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Prep Area! [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
This is done in [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
TIPM[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
(Total Integrated Power Module) Programming Options. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
With [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
StarScan[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
(or with 2010 and newer [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
StarMobile[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
or [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
WiTech[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
)[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
go into [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
setup.[/SIZE][/FONT]
Note: Do not use [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Wycliff[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
for this! [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Note:[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
We can do this also for add on "fog lamps" on other models. [/SIZE][/FONT]
ECU View [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
---[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
M/CGW [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Misc Functions [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Enable DRL [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
follow prompts. [/SIZE][/FONT]
Check the status of the DRL and see if its [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
ENABLED[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
It is not listed as [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
"Daytime Running Lights"[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
but it is actually listed as [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
"DRL" in the scan tool. [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
When vehicle is placed [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
in gear[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
and parking brake is in the [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
OFF[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
position, the [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
DRL's[/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
will then automatically come on. [/SIZE][/FONT]
Q: [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Just to be clear: the orange (inner most) lights can be set to DRL mode following this procedure? [/SIZE][/FONT]
A: [/SIZE][/FONT][FONT=Verdana,sans-serif][SIZE=-1]
Yes, but only in gear, no parking brake on, it will turn on the turn signal element in the front lights only.[/SIZE][/FONT]
