1 - 1 of 1 Posts
Having some issue with the drive's seat and I was hoping for a fix if someone knows what to do.
I can not recline the seat and it actually is looked in a slightly forward position. I pull the level on the seat back so I can flip the seat forward and let a passenger in and out. Okay it does this just fine but when I push the seat back it stops and basically locks in a slightly forward position toward the steering wheel.
I've tried sitting in it and pulling the lever and reclining the seat backward but it won't budge. It will only flip forward and then as I described will not go all the way back.
So I'm guessing it's out of sync or some type of alignment with the little claw that actuates when you pull the level on the side of the seat. Anyone have an idea what I can look for to correct this before I run by a dealer have them look at it.
1 - 1 of 1 Posts
