Hello, I have a good one for you.
Recently I purchased a NAV Map upgrade from NAVTEQ. Upon trying to update the Map in the radio using the DVD my activation key was coming up "invalid". A new key was gien and still "invalid". After support from NAVTEQ the following was found. When in the NAV menu and selecting "database info", the VIN is blank! Because there is no VIN in the radio the upgrade cannot be completed.
NAVTEQ indicated at that point that they could not help me and to go to the dealer. Well I called the dealer and they indicated that they have never heard of this before. All he could suggest is an entire re-flash be done as if the car came right off the assembly line. He said even doing this may not fix the problem.
Could it mean that this radio was installed from another vehicle? If it was it should work? Is here a comm link from the radio that sends the broadcast of the VIN to all components? Could this be disconnected?
The radio is functional in every way. I was also able to complete the radio system update successfully.
The radio is the 730N RHR.
Any thoughts on this issue?
