1 - 20 of 26 Posts
I while back I ordered 4 SFT of 3M DI-NOC Burma Teak Wood Grain Vinyl Film to wrap my gauge cluster, center console, and radio cluster. I ordered a pry removal kit from Amazon for 10 bones that is essential to get the pieces pried off.
I performed the gauges first:
-Remove push tabs from kick panel
-Remove fascia of cluster by gently prying out the push tabs leaving the cluster in place:
-Place fascia on back side of vinyl wrapping and use a felt tip pen to start drawing the outline of the cluster
-Cut cluster out of wrapping leaving 1/2" or so of excess material so you can stretch and form the material
-Remove backing from wrapping and place fascia on sticky side of wrapping
-Start applying heat and gently start forming to the fascia
-Taking your time slowly start forming and trimming the vinyl wrapping. I found it best to cut (+) sign relief cuts around circles and pull each of them around the fascia. Then with a scalpel I trimmed around each gauge. This is a time consuming step but is what gives you your finished product. With the accents and lines of the fascia it is a more difficult piece to wrap and am sure I could do better now that I have done it:
- To finish just push back in place:
I then did the center console:
-Begin by removing bezel around shifter, held in place with push tabs and then remove console (also held in with push tabs, just work slowly around until they are released):
-Then place on wrapping and trace out shape and trim to size
-Peel off backing and place on wrapping
-Begin applying heat and forming to shape
-Again using relief cuts around the cup holders and inserts slowly apply heat and form to shape
-It takes a lot reiterations of applying heat and forming (If you mess up, you can apply heat and pull back and try again, pretty workable in that fashion)
-This was the easiest of the three pieces to do
-To re-install just push back into place
Next was in radio cluster (and the most difficult and a PITA):
-This piece is also held in with push tabs, but the climate control and bottom buttons are bolted onto it
-Remove sensor clips on all the attached equipment
-To remove the climate control and bottom buttons you some very small non-normal socket (thanks Dodge), I was able to find one that worked at the forth store I went to size E6 and is more of star configuration instead of hex head that the bolt is it is probably around 3.75 mm.
-Again place on wrapping, trace, trim, remove backing and place on wrapping
-Apply heat and slowly start conforming to surface
-This cluster has so many contours on it and is why it is the most difficult of the three pieces
-Just apply heat and work slowly
-I wasn't happy with how the material handled the contours around the buttons and climate control so I trimmed these pieces out and will probably pick up some black paint to cover the carbon fiber pattern
-Re-install the electronic sensor units and push back into place to complete the project
I really like the finished product and how it looks. This is a time consuming project and the level of difficulty is moderate to moderately hard. If I was to do it again I would of hydro-dipped all three parts although it would have cost a lot more. The wrapping is relatively cheap (30 bucks for a 4-SFT sheet). so you can always order more and do it again if needed. I would say this took me 6-hours or so to do. Your fingers will hurt after all pressing and pulling of the material.
Here is the car finished:
Tools required for installation:
· Packin up my game gonna head out west....
Thanks for the write up. Did you opt to use tape primer at the under side and edges? I've got a fair amount of primer left over so I was thinking I'd use it on the sides and undersides of the trim peices. It might not be needed but I was debating getting knifeless tape for some of the curved areas that need to be cut out.
For the socket to remove the climate controls it almost sounds like a torx but in reverse fashion where instead of having a bit you need a socket to remove it?
Take it easy
Jay
A great classic look!! Very well illustrated!
Discussion Starter · #6 ·
That looks very cool.
Thank you!
Take it easy
Jay
Jay, I just cleaned the parts with alcohol and a microfiber and didn't use in any primer. The material adheres to the plastic really well and didn't have a problem with it not sticking.
The socket was strange, wish they would have put a Phillips head screw instead of a non-normal small hex head. The hardware store, radio shack, and one Napa didn't have anything that small. The second Napa had the E6 socket that would grab it enough not to strip it.
I like that, a lot! :smileup:
Thank you!
Thanks Betty!
Thanks for posting this! I can't rule out doing something similar someday, and this could certainly help.
:rep:
Discussion Starter · #10 ·
:rep:
No problem if you tear into it and have questions, let me know.
Great job! Nice write up:smileup:
That looks sharp:smileup::smileup::smileup:
Thank you!
One thing I forgot to add I was waiting until winter to do this, so while it was minus 20 something last night (55 in my garage) I got this accomplished. Like a lot of folks I haven't been able to drive much this winter. As other have witnessed all around the country, this has been a bad winter. (Al Gore was almost right with his global warming bs)
Well done! I am doing the same thing with 3m di noc in carbon fiber red. Got the center console, radio bezel, and ac vents done. I can pop the overhead console, but for the life of me cant get the wire to unplug. I also want to do the door pulls with that fake looking hydro dip on it, but havent figured how to get those out, or if i will just do them inside the car.
After you take your door panel off, there is a Torx screw(if I remember, T25 or T27) at either end of the pull holding it into the panel. You have to use a short L shaped wrench. And it is slow work. Can't work a socket into the area.
Nice job and write up. You say it took six hours but don't specify the amount of Bud Lights that it takes to do the job LOL.
Discussion Starter · #16 ·
Thank you! Yeah it took me about two hours per piece spaced over three nights. This was sixer type if install for me (one an hour ;)).
Have you figured out how to do the steering wheel pieces yet? I am guessing you have to pull the center off somehow and pop them. Last car I did this on was a hidden torx. I havent looked real hard cause it is so damn cold.
· RELIVN
That was a great job and took a lot of patience. Was not a real fan of that look until I saw yours. Awesome.
1 - 20 of 26 Posts
