Well, maybe you need to 'get it right' yourself before you go preaching to others......check this out for your info, since you say I am wrong....straight from the dodge website....sure looks like 15/24 to me......
As for swapping the numbers around...what does that get you ??
Lat time I checked, 13, 15, 21, & 24 were all different numbers, so I merely questioned your use of the term 'identical' when talking about their mpg ratings.
I used actual numbers from the dodge website (even compared wide body to wide body, auto trans to auto trans).....not sure what you were comparing............or why you are trying to say I swapped them around for some reason.
Also not sure why you are even still trying to argue over this, the rating numbers are clearly NOT identical.....but if it makes you feel better, about what you bought & how you drive it - more power to you.
I didn't buy what I have for mpg either....or I would not have a v8 engine........
