1 - 5 of 5 Posts
I'm installing a snow performance methanol injection kit on my 2015 R/T. I'm putting the pump and tank in the trunk but I need to run the pump hose and MAF sensor wire to the engine bay. I'm going to try running them under the interior trim to the firewall. Is there anywhere that is easy to run them without drilling holes or running them under the car? In the front and trunk fuse boxes, is there a common location in the front and trunk that I can just use instead of running a wire?
Behind the steering column there is a bung that you can pierce to gain access to your engine bay. I used this to bring power into the cabin for my NoWeeds cutoff switch.
You will have to make a slit in the bung. Given that you're looking to run a tube and not just a wire, I'd strongly suggest you insert a pvc conduit through the actual firewall/bung through which you can run your meth hose; this will prevent any pinching of the tube over time.
1 - 5 of 5 Posts
