Did you put 255's all the way around, or only the back?I have 255/45-20 on my car, 255 is the widest you can officially put on a 8" wheel unless you go to a tall truck tire.
Yes, all the way around, I love the look but the speedo will be off a tiny amount unless you have a tuner to recalibrate it. I do have one.Did you put 255's all the way around, or only the back?
Were you satisfied with that size or do you prefer the 245?
I don't see that happening, the HellCat might get 275's all the way around but I see the regular versions staying 245.The 2015 challenger I believe went stock 275 all the way around the car. Has better grip and the look is great. The max tire size I believe on stock wheel is the 255.
Amazing the difference 10mm makes.Yes, all the way around, I love the look but the speedo will be off a tiny amount unless you have a tuner to recalibrate it. I do have one.
I drive pretty easy and my F1's were down to the wear indicators in 18k.Amazing the difference 10mm makes.
Again, I'm looking ahead to when my F1's are ready to go.
I'm an easy driver so I'm hoping to get 15-20k miles.
BTW, what tires to you end up getting?
I would have thought that was too wide for the 8's.I'm running the 275/40 20s on the rear with the 20x8 chrome clads without a problem. And the stock F1s in the front. Same height all around.
Motivos? Seems lots of people on the forums use that tire. Are you using any spacers too?I have 255/45-20 Nitto's all the way around on on stock Heritage wheels. I'm lowered 2 1/2 inches in front and 1 1/2 inches in back. No rub problems and the tires fill up the wheel wells better than the 245's.
No spacers. And not Motivos, but similar. 850 CUV Plus.Motivos? Seems lots of people on the forums use that tire. Are you using any spacers too?
Ok, thanks for the info.No spacers. And not Motivos, but similar. 850 CUV Plus.
How much and how many miles on them?I have 275/40ZR20 BF Goodrich Comp 2 all the way around on 20 x 9 SRT Wheels. Great look and car grip the road so much better.
Someone should buy these from me![]()
I'm in the market for some str wheels for my r/t but I want black not chrome. Do the 275/40/20's rub in the front?I have 275/40ZR20 BF Goodrich Comp 2 all the way around on 20 x 9 SRT Wheels. Great look and car grip the road so much better.
