1 - 7 of 7 Posts
Hi Guys
i live in sweden and you can more or less not drive a car like the Challenger from November to April, så my car is parked in a warm garage.
I Googled the internet on what to do before parking the car for such a long time.
My biggest worries are the battery. i read on several pages that the car will have some problems if you disconnect the batterie, specially if you have the automatic gearbox (wich i do).
What do you do with Your Challengers that are parked for a longer period of time?
"Turn on, tune in, drop out"
Get a battery tender (not a battery charger) and use that for winter storage. It is a trickle charger meaning once the battery is charged, the tender goes into standby mode and will only kick on as needed to give it juice when needed.
I have a Deltran I have been using for years
Like Tiki said.....a Battery Tender is key......it hooks right up to your car battery. Also a bottle of Stabil or Seafoam in the gas tank.
Discussion Starter #4
This is what i did in october.
i pumped the tires as mutch as i could så they wouldnt be deformed when standing still for 5 months.
I had almost NO gas in the tank.
AND, what i did with the battery was that i unplugged the IOD fuse so the battery wouldnt completly drain out.
http://www.justanswer.com/dodge/84iqe-dodge-challenger-disconnect-battery-storing.html
anyone tried this?
is it to late to try with the Battery Tender now?
You will find a lot of info in the Winterizing section:
http://www.challengerforumz.com/forums/winterizing.171/
I don't have to store my car, as live in Florida and drive it year round. However, in the past when I winterized motor (boat), I would do so with a full tank (and Stabil) to prevent water from condensing in the tanks.
Slower Traffic Keep Right
I have also heard of folks jacking their cars up and placing them on stands.... Is it in a secure area as far as critters? Mice can do a number on a car....
Hi Guys
So the battery was completely drained, i have to recharge it.
i read somewhere that the automatic gearbox loses its settings when disconnecting the battery.
1 - 7 of 7 Posts
