1 - 15 of 15 Posts
‘22 Smokeshow T/A 5.7, Plus, Auto, Hood Pins, Convenience, Sunroof, Alpine w Sub, Compact Spare
Hi all! Thanks for taking the time. I love the cold start sound and volume on my ‘22 5.7/A8 T/A and I’m wondering if I install the Z Automotive kit will I always have that sound as if valves are wide opened. I do hear a difference in the sound between a 5.7 and 6.4 so would appreciate first hand experience with a 5.7 setup like mine.
Also, I don’t know if with a cold start all eight are working and then switch to 4 after warmed up. If that’s the case then I would expect a volume drop?
Wheel Tire Water Sky Vehicle
2015 R/T 5.7L A8
It is supposed to trick the system into thinking the Active Exhaust is operating normally but the valves are always open, and there is no check engine light. The MDS feature on the automatic will still be operational, but Sport Mode disables the MDS, as does pulling the auto stick towards you into manual while cruising.
IMO it looks like the smartest solution yet to the Active Exhaust and keeps your stock parts in place in case you need to convert it back. Ry
2021 R/T Scat Pack Shaker Widebody M6
While I have the 392, I disliked how the valves would close and ruin the cold start sound. I installed the Z Auto modules and couldn't be happier. (y)
2017 GREEN GO HELLCAT CHALLENGER
what's the website for those, I'm interested. Thx in advance
I think I like this product better than the MFER-1-EXTREMES i was looking at . thanks for the info
Reactions: SmoknTA and FOSSS
I have a T/A 345 A8 and my active exhaust is always open (done by a speed shop). When I startup, I get that high idle than slows down to that lopey sound.
Nice rumble. (y)
This will fix my error code for valves correct.?
Yes, I didn't get any codes when I installed them. And the valves stay open all the time.
Reactions: SmoknTA
End of season I had a code come on for the exhaust valves and didn't do anything yet.
Reactions: SKT PK 9 Man
1 - 15 of 15 Posts
