Also, late to the party, but as mentioned, you want to drive it. I ordered a new 1994 25th Anniversary and did the car show scene. My girlfriend (now wife) and I won many awards with it. I put it away with exactly 11,111 miles on it the last time I drove it. However, life got in the way and it was sitting in a non-climate controlled garage for about 11 years, so it needed a ton of work done. New battery, fuel system flushed, new fuel pump, fuel filter, oil change, air filter, new tires (balance and alignment), new master cylinder, brake fluid flushed and replaced, new fuel injectors, fuel injector pressure regulator, sway bar end links front and back, flush and replace transmission oil, new serpentine belt, drain and refill coolant system, new thermostat, new torque arm bushing, differential service (replace fluid gasket etc.), new air conditioner compressor. Power windows were working intermittently new regulators. I'm sure I'm forgetting a thing or two but you get the idea. I won't make the mistake of letting a car sit to long again.
